I really dislike Windows media player to create playlists.
Do you recommend any playlist editor/creators? Ideally, it should be really easy to use, doesn’t take up much space or RAM, is free or reasonably priced and works with all MP3 players
I’m not looking for Winamp or Media monkey type software. Just something that easily creates playlists.
I’m new to the forum (and I only got my Fuze yesterday), this is my first post, so please be gentle with me.
Apologies if I’m resurrecting an old thread. I shared the original poster’s views on not wishing to download another music do-all. And I didn’t want to use wmp
I use fre:ac to convert music to FLAC, which is minimalist, but seems very good so far. It’s not so good for manipulating the order of playlists however.
I am a little confused by the difference between step 4 and step 5. At what point prior to step 5 were you supposed to save anything to the desktop, and why?
[quote] STEP 4 - Rename the playlist
Disconnect device from the PC.
Switch the USB Mode to MSC. From the Main Menu , select Settings > System Settings > USB Mode.
Select MSC.
Connect your device to the PC.
Go to the MUSIC folder.
Rename the New Playlist.pla and New Playlist.pla.refs files to your desired playlist name.
STEP 5 - Rename the playlist
Switch the USB Mode to MSC. From the Main Menu, select Settings > System Settings > USB Mode.
Select MSC.
6. Copy the playlist and songs from the desktop to MUSIC folder.
Rename the New Playlist.pla and New Playlist.pla.refs files to your desired playlist name.[/quote]
