Player will not start without flashcard(((
For last 7 days my player acting differently.
When external memory card is NOT in the player, the player get stuck for a couple hours in this loading
     http://clip2net.com/clip/m224059/1397595063-clip-30kb.jpg
After 2 hours it loads completely but will not respond to any key. To turn it off I need to hold off switch for 30 seconds (yes, I counted))).
If flash card is in the player (not any card just one for 32GB)))) it loads and works OK)).
Any idea why it start doing this?
I’ve tried to perform  Firmware Update
it always cuts off on the same spot each time on 80%
http://clip2net.com/clip/m224059/thumb640/1397449780-clip-48kb.jpg
I also copied the  SansaUpdaterInstall  file into rut directory on the player:
http://clip2net.com/clip/m224059/1397596277-clip-34kb.png
Then I took the external memory card out, then unplugged the player from the computer.
player tells me the it refreshes the media:
http://clip2net.com/clip/m224059/1397596891-clip-22kb.jpg
and that’s it.
It does not turn itself off as instruction says and it does not update firmware. ((
I don’t understand what I’m doing wrong…
By the way I cannot connect the player with no external memory card to the computer because then it does not recognized by computer.
It’s only last 7 days like this.
question #2
I have another Sansa that fell down on the hard floor and cracked
it looks like this now
http://clip2net.com/clip/m224059/1397597585-clip-54kb.jpg
http://clip2net.com/clip/m224059/1397597648-clip-46kb.jpg
When I connect it to the computer I get the message that I need to format it.
but then it cannot complete the action:
http://clip2net.com/clip/m224059/1397597847-clip-35kb.jpg
is anyone in Dallas (TX) aria can fix this??
OK. I found out that I used wrong file for firmware update. I got the rigt files (clpp_data,  fuzpa ) and succesfully updatet firmware today.
But the problem still there. the plyer will not load if external memory card is not in it!
Nice of you to share the steps. At first glance I thought the boot files were stored in the card.
Why? :confounded:
