I have a sansa fuse+ and when i plug it in to my computer it says its charging on the mp3 screen but when im in the properties page it says battery level 0 and it wont turn on when plugged into the wall please help
Makes sure your Computer is not in sleep or Hibernate mode when the sansa player is charged through ur PC as it will terminate ta connection.
Try resetting the player by pressing the power button for approx. 30Secs and then try switching it on.
if it doesn’t work then contact sandisk Support for replacement of ta product if ur player is still under warranty.
