i think that sandisk plans a update of the software that will change this feature with the missing life attribute and it will show up normally. Furthermore you shall not be worried about the fact that you write a lot of GB on the drive. I also own a sandisk SSD and have wirten over 100TB and is still working perfectly fine.
still you can contact the support of sandisk if you still have questions about your ssd drive
still you are using the SSD dashboard software that will let you know if something goes wrong with the drive so you are aware and replace it with a new one.
the SDSSDEXT is the portable SSD that sandisk has and the SDSSDHII is the normal SSD SATA drive. so i guess you are using the normal sata drive with your computer.
