Extreme slow write performance on Sandisk Ultra Plus
I just installed my new SanDisk SSD (Sandisk SDSSDHP-256G-G25 Ultra Plus). But I get extremely slow write speeds (see Screenshot).
I disabled the write cache on my system in order to see the “real” speeds. I’m using Windows 8.1 Pro, AHCI is enabled.
Any suggestions?
EDIT:
I get these results, if I enable the write cache. Write speed is quite bad, too.
Check your partition alignment.
Thanks for your answer. The alignment is set correctly.
Still waiting for help…
speed looks quite a bit better with wite cache enabled. What SATA chipset are you using? Can you benchmark using crystal disk mark and post the results as well?
