How do I delete all my music? I want to change it.
The easiest and quickest way to delete all user-added content is to format the player.
I don’t recall how long the re-format takes.
Or, just connect the player to your computer (which you’re going to do anyway, to transfer new music to the player), open the Clip folder, select all the music, and delete.
I linked it to my computer and that worked. It creates a computer file that can be deleted. Thanks.
