frb1999
December 14, 2013, 12:14pm
1
Hi at all you.
I have a problem! One my friend broke him Sandisk Cruzer Switch 5gb and its pcb is divided on 2 part.
Fortunately the flash chip is whole!
I don’t know how the pcb is done but I think that its a multilayer pcb… than I can’t repair it with simply reconnect two pieces!
I thinked that if I wick the chip and I connect it on a solder-less breadboard I can rebuild the chip… but I haven’t found any datasheet.
It was difficult rode what there are on the chip, but I think it’s:
SANDISK
6260523-1
546284934
8DC1
TAIWAN
No datasheet and I think 40 I/O. Someone know if it’s possible? And someone know if the datasheet exist?
Thanks, Francesco
ed_p
December 14, 2013, 6:24pm
2
Tell your “friend” they owe you a new Switch and all the files you had on it. Hopefully you have backups for the files.
frb1999
December 15, 2013, 10:06am
3
The real problem is that he haven’t got a backup of his important files that the usb keys contains.
I know that he teoricly have to do one backup but… I don’t know what I can do.
ed_p
December 16, 2013, 3:00pm
4
Unfortunately I’m not sure there is much that you can do. You can look for a local tech shop and see what they suggest but I suspect the files on the drive has gone to the bit bucket in the sky.
Good luck.
Looks on the bright side though, you have plenty of reason to shop around these holiday for a new flash drives. Discounts are all over the place!
frb1999
December 27, 2013, 12:47pm
6
Thanks, I told him that him usb key is dead…
Newly thanks at all;
Francesco
