Used to charge all the way.
Any help appreciated
Thanks
Thanks
Hello!
The charge indicator is a close estimate of remeining battery life based upon past peformance. If the battery is routinely “topped off” by plugging in, over time, the device may need to relearn the characteristics o fthe battery. Mine do this a bit over time.
You can simply use the device until it shuts down, then recharge. This “long cycle” is all that’s needed for it to relearn.
microsansa
_microsansa, _Do you mean that I cannot have uninterruptable power supply, as requested in http://forums.sandisk.com/t5/User-guides-Firmware-Software/Playback-unterruptable-by-power-supply/td-p/337551?
Yes! Thanks for sharing the info. Very Useful.
