Clip Sport Dead?
My Clip Sport seems to be dead, but there is something going on in there. I’ve looked through other posts and see that a reset is recomended. I can see that when I hold the menu/power button for approx 20secs that there is a flicker on the screen and there is a very slight back light. This is as far as it goes. After this it does not change on the mains or power (or be recognised) on the laptop. Last night when I was plugging it into my laptop it sounded like my laptop was detecting something, but tonight nothing.
Any suggestions? The device is about 10 months old
Maybe try leaving it connected to a charging source for 3 hours?
Then try the menu/power button reset as you described.
Then press that button for 1 sec to turn on as normal.
