I have a Sansa Clip plus and it has just stopped working (after about 6 months’ use. It hasn’t received any physical trauma).
MS Windows can see it fine, but when I try to turn it on, the screen is blank blank blank. Same goes when I plug it into a mains charger - the device shows nothing on the screen. I have tested the charger on other devices and the charger is fine.
I guess that either the screen or battery is kaput.
Is there anything I can do ? I tried the autofirmware software update, but it hung on clicking the ‘finish’ button.
You might try manually reapplying the latest firmware (see the firmware sticky thread in this forum) and/or manually reformatting the player using Windows (note that this will erase your user content on the player–transfer anything you want to save to your computer first).
