Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
![]() Posts: 0
V-mate remote ControlOptions
01-07-2008 12:26 PM
Just bought a scandisk V-mate which worked very well for about one hour. Then the remote control stopped working. The retailer has been very helpful and has offered to replace it and I am waiting for the replacement remote to arrive. I did read one internet review which experienced a faulty remote. The remote control is pretty flimsy, has anyone else had problems with their remote ? Does anyone know if any other more sturdy remotes can be used with the v-mate as I now can't see the replacement lasting forever! Thanks.
![]() Posts: 0
Re: V-mate remote ControlOptions
03-06-2008 03:53 PM
Hi. could you please tell me the retailer that gave you another remote?
Thanks. ![]() Posts: 0
03-07-2008 03:14 AM
I bought my v-mate from an ebay seller. You should be able to get a remote direct from sandisk ( v-mates have a 2 year manufacturers warranty )
