I have 2 fuzes that I sync and recharge on the same laptop. Is it possible to use only 1 up grade for both?
So far the update recognize V2 fuze but not V1.
Please help.
Please help.
Each hardware ‘version’ of the Fuze has different firmware. If using the Updater, it should recognize which is which when the device is plugged in and download the appropriate version. Or you can simply install the update manually and get rid of the Updater altogether. It only takes a couple of minutes. Directions are in the Firmware posts at the top of the Fuze board’s main (or 1st) page.
