Ultra II Memory Stick Pro Duo / PSP compatibility
hi,
A friend is lending me his PlayStation Portable that he never uses, and thus doesn't have a memory stick.  I'm looking to buy one to use and was wondering if the Ultra II Memory Stick Pro Duo would work in the PSP.  The compatibility chart recommends the regular memory stick pro duo but the Ultra II costs just a few dollars more.  So if its compatible I'd like to get the Ultra II instead of the recommended.
Re: Ultra II Memory Stick Pro Duo / PSP compatibility
Yes, it will work without a problem.  And it will give you a lifetime warranty.  One thing though, if you are buying it because of the speed it offers, you might be disappointed.  The PSP would have to be able to read and write at that speed to take advantage of it.
Thanks fuzzy logic.  I was thinking that after I return the PSP, I could use the memory stick in other devices, should I ever buy a sony camera or such.  Thanks again.
