Re: Error Code: 0x80070052
I bought 2 Nextar MA715 MP3/4 Players @ 2GB and had the same problem.
I fixed it.
1. No more than 109 files per subdirectory.
Then you can have 190 Sub directories with 109 files in each dir.
109*109 = 11881 Files per memcard.
I dont know what the deal is with SD cards, But they are quirky thike that.
I remain: Shinobiteacher1
@Shinobiteacher1 wrote:
@I bought 2 Nextar MA715 MP3/4 Players @ 2GB and had the same problem.
I fixed it.
it is not the SD card it is the file system used to format the card. maost devices 2GB and smaller are formatted with FAT. i suggest reformatting cards into FAT32 since it does not have the same limitations FAT has.
Thanks.  I did re-format the card to FAT32 and that solved the problem.
I get this Error where all these dirty websites pop up at the same time when I put my 8GB SDHC in to my MicroMate. What the flip is going on? My computer crash's every time! So, I can't Format my SanDisk 8GB SDHC with my Black MicroMate. Help me!
it sounds like you have a virus on your card. maybe try going into safe mode without network and try a format from there or use a MAC or Linux box and try to format the card.
how did you reformat this into FAT32?
