SanDisk Guru
Re: Players with more than one card slot?
[ Edited ]
I'm frustrated. I still haven't found any players under $100 that are better than my Clip+ or Fuze. Perhaps I may end up buying a player with a large screen and android, even though I don't really need something so advanced. Even these players though still don't have more than one card slot. Hopefully players with more than one card slot, 40+ hour battery life, and HD radio will become available for under $100 within the next year or two. Having GPS on a player would be fun, as long as it doesn't substantially increase the price.
SanDisk Guru
My Rockboxed Clip Zip is a bit better than the Clip+. I'm still waiting for longer battery life, HD radio, and a second card slot.
SanDisk Guru
[ Edited ]
Only player I know of with a second card slot is this one.....
http://www.amazon.com/Astell-Kern-AK120-Dual-DAC-Mastering/dp/B00D648BDA
And there is no way in hell I would buy it.
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
