SanDisk Guru
Accepted Solution
Avatars
I would love it if we had the option of adding our own avatars, and I'm guessing a lot of others would like different choices than we find here currently. Are you with me people?
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Guru
Re: Avatars
Me too! Me too! Smiley Happy
Administrator
Re: Avatars
[ Edited ]
All Sansa Gurus now have the ability to use externally hosted files as their forum icon. Please use discretion when choosing an icon. You new icon will need to adhere to the forum rules and guidelines so no profanity or nudity.
In your profile on the icon tab there will be a personal icon URL. Here you can enter the URL of your chosen icon and it will appear as your avatar.
Forum Admin
slotmonsta
Message Edited by slotmonsta on 05-01-2009 12:08 PM
SanDisk Guru
Re: Avatars
Thanks slotmonsta!
SanDisk Guru
Re: Avatars
Slotmonsta is the man!
Conversion Box
Did you notice this forum has a search function? Its not impossible to figure that someone else asked your question before you did, and we have answered it(probably multiple times). Check it out! Or Check out the Knowledge Base
SanDisk Guru
Re: Avatars
Slotmonsta,
You're all right, no matter what they say about you.
Bob   Smiley Very Happy
SanDisk Guru
Re: Avatars
I don't have the box to enter the URL for a custom avatar. Whasupwidat?
SanDisk Guru
Re: Avatars
Did you click where it said "Icons"?
SanDisk Guru
Re: Avatars
Yes, I did. The only text entry box I see is for the Search function.
SanDisk Guru
Re: Avatars
It should be down at the bottom...on the left it says "Personal Icon URL" and to the right of that is the box. Under that box are buttons for "add icon " and "reset". At least that is what I see.
