Newbie
usb charge help
has anyone tried to charge the sansa e200 using an ipod usb charger ? seems like the conection is the same using the sansa usb cable , thanks for the atention to my question
SanDisk Guru
Re: usb charge help
the fit the same, but they arent the same pins on them. You can potentialy mess up eithier the connection or the player itself when trying to mix eithier of the two.
Great For Beginners:
How To Videos
FAQ's and Stickies
Any-Video-Converter
____________________________
- Enigma
SanDisk Professor
Re: usb charge help
iPod chargers work fine, contrary to what was said above, iPod chargers are USB, and therefore follow guidelines, which all you need is the cable that came with the sansa and you are rolling Smiley Happy (I think enigma or I was confused about the cable or the charger itself)
SanDisk User
Re: usb charge help
USB pins are universal (that's why it is called Universal Serial Bus), so no problem with the charger should occur, unless it has malfunctioned. But when discussing the cable, you must use Sansa original connection cable.
Photo Sharing and Video Hosting at Photobucket
