Highlighted
Newbie
e280 not napster to go compatible???
I have an e280 v.1 which I have been using with napster to go for about a year.  now when I connect the device to the computer, Napster says that the device is not Napster to go compatible and I have to purchase each song.  Napster lists the item as compatible on their website.  how do I fix this?  Thanks in advance for any help.
Highlighted
SanDisk Guru
Re: e280 not napster to go compatible???
Make sure under Settings/USB Mode that you are in MTP mode.
Can't Connect? Other Problems? Answers
