SanDisk User
Will a Lexar 2GB Micro SD memory chip work?
Is Lexar any good? It seems to be cheaper but is there a good reason for this? Does anybody else have one of these? Will it work in my e270?
P.S. I'm still waiting for the SDHC support.
SanDisk Professor
Re: Will a Lexar 2GB Micro SD memory chip work?
You might not see microSDHC support with the Sansa firmware.  You might have to install Rockbox.
SanDisk User
Does anybody know why?
SanDisk Professor
The format of the ds and sdhc is slightly different. in answer to the original question, anything that doesn't say microsdhc on it should work. Smiley Happy
