Newbie
Problem
Hello, I have a Sansa e270 since 1 month, But now I can'T turn it on.... I thought it was a bad battery so I took off the cover, and the Mp3 turned on....but when the cover is instaled, it stay off.... what can I do  ???
SanDisk Professor
Re: Problem
What happens if you connect it to the computer. If it turns on, it should be the battery, if it doesn't, there is somehting wrong, get it replaced Smiley Happy
Newbie
Re: Problem
When I connect it to the computer, it turns on...but the battery's good 'cuz when I took off the back cover I can turn it on....
