Highlighted
SanDisk User
Music Folder problem
Hi everyone ... Noob here.
Just got a E200 8MB player. Some folders under the music folder don't show up. Instead all the songs go into "unknown".  Example. I just created a folder called AC DC under the music folder. I copied 5 mp3 files into the AC DC folder. The AC DC folder does not show up on the player but shows up in Explorer. All the mp3 files go into a folder called "unknown" ???  Help!
Highlighted
SanDisk Senior User
Re: Music Folder problem
The music is sorted by the ID3 tags, if the tags have no information then the player sorts them into unknown artist folders. You can edit the songs by right clicking them in Windows Media player and selecting Advanced Tag Editor.
Highlighted
SanDisk Guru
How to videos for editing ID3 tags
WMP11    WMP10
Highlighted
SanDisk User
Thanks fellows!  I'm on my way with this player Smiley Wink
