Highlighted
Newbie
E260 problem it doesnt turn on
my e260 isnt working while its unplugged , it just dont turns on and when i plug it to computer it says load image failed help me i dont know what happens i have had it for like 2 weeks only
Highlighted
SanDisk Guru
Re: E260 problem it doesnt turn on
Is this a new or "refurbished" unit?
Is is a v1 or v2 model? Look here to tell the difference.
If it's a v1 follow C1u31355's updated instructions here (4th post down from top).
If it's a v2 model or if you're not comfortable with the procedure, AND there's a warranty, send or take it back & get a new one.
If it's a new one, it shouldn't be crapping out on you already.
If it's a "re-furb", then "ya gets whats ya pays for", but even those should have at least a 30 - 90 day warranty; so if you have to, use it.
Good Luck! Smiley Happy
Highlighted
Newbie
wtf i didnt know about that refurbished thing and its a v1
