Highlighted
Newbie
sansa clip zip sync problem
When I sync to my sansa clip zip with it syncs songs that are already on the device. I think its because the file modification date doesn't update. The modification date on a file on my hard drive would be 13/08/2012 but when you put the track on to the clip its 13/03/2005. So the program I sync with thinks the files need to be updated. Is there a solution to this.
Highlighted
SanDisk Guru
Re: sansa clip zip sync problem
This is the View board.
