Highlighted
Newbie
sandisk sansa view display problem
Hi
I bought sandisk sansa view 8 gb player today when putting my ear phones unfortunately my player fell down and display is not working is there any way to solve this
Waiting for your replies thanks in advance
Regards
Sai Gopal
Highlighted
SanDisk Guru
Re: sandisk sansa view display problem
Most likely you damaged the player by dropping it.  You could try any "reset" options available in the View's menu system (I'm not familiar with it).
Highlighted
Newbie
hold the on switch up for 20 secs suposeedly this rstarts it? It works when it freezez (on a reguar bases).
Highlighted
SanDisk Guru
Try the "reset factory settings" item on the View's menu.
Again, this is a stretch.   More than likely your View has physical damage.  If so, the only thing left is to physically manipulate it back into working order.  ;-)
Highlighted
Newbie
I have this same problem.  How can I physically manipulate it to work again?  Or is there a place I can find a new lcd screen?
