Highlighted
Newbie
Sansa won't turn on anymore
On the way to school I was listening to the music on my sansa and when I went to change the song the back light wouldn't turn on,
only the blue lights of the spinner and buttons. So, I turned it off thinking it was just a little mishap but then it wouldn't turn on at all.
When I got home to plug it into the computer to see if it would start working there, nothing happened. I appreciate any help anyone can
give me on what is wrong with my 16g sansa view. Thanks!
Highlighted
SanDisk Senior User
Re: Sansa won't turn on anymore
Hold power button up for 15 s, release, then turn on. Make sure it is back to room temperature before doning anything. Also, once its been turned off you need to wait a while before holding the power button up, or it won't work.
