Highlighted
SanDisk Senior User
Sansa View Firmware 01.02.09 Download
[ Edited ]
This is an old firmware version. As of June 30, 2008, SanDisk released a new firmware for the Sansa View.
Let me start off by saying that majority of people will be able to update his/her firmware through the Sansa Firmware Updater. There is even a how-to video that explains the process. If for any reason the aforementioned steps do not work for you, then please feel free to continue by trying the more "computer savy" steps, described below.
Sansa View Firmware & Instructions
Latest: 01.02.09
New Sansa Firmware Updater (Windows Version Only) -
The latest Sansa Firmware Updater will update the View to the latest firmware.  If you do not have the Sansa Firmware Updater it can be downloaded on the following page (click the link) - http://www.sandisk.com/Retail/Default.aspx?CatID=1376
If you prefer to use the drag and drop file method, then please follow the instructions below.
Mac
and Linux users can connect their View in MSC mode and follow the instructions below.
MSC mode instructions:
  1. Turn on the View
  2. Put the device in Hold (move Hold button until orange is showing)
  3. Press and hold the Left Button
  4. Plug the 30 pin connector into the device (be sure the USB is plugged into the computer)
  5. Wait for View drive(s) to mount
  6. Follow instructions above and drag files to the View drive
SanDisk has just released the 01.02.09 firmware revision for the Sansa View. Download links and the release notes are available below.
For AMERICAS - You can download the .zip file by clicking on this link.
For EUROPE w/ FM - You can download the .zip file by clicking on this link.
  1. Extract the .zip file into a folder on your computer.
  2. Once extracted, drag all five files file to the root directory of your Sansa View.
  3. Disconnect the Sansa View and let it restart. (see notes below)
  4. The firmware update will now begin.
  5. Once it finally finishes doing its update, it will boot back up. Once its back to the main menu, head to "Settings / Options" > "System Settings", and verify the "Version" is now 01.02.09.
Note - Upon completion of the firmware upgrade, the device will restart. If the restart does not initiate or complete, press & hold the Power switch for 8 seconds to reset the device and then release and press again to restart.
Additional Note - The Preloaded Video on the View will no longer playback with this version of the firmware. The video playback specifications for the View has not changed.
Sansa View Firmware 01.02.09 Release Notes
This new firmware has various bug fixes, including a fix for a known device “hang” problem associated with playback of certain unsupported video file formats. Only videos within the Sansa View supported profiles range will playback with this new firmware. Upon completion of the firmware upgrade, the device will restart. If the restart does not initiate or complete, press & hold the Power switch for 8 seconds to reset the device and then release and press again to restart.
Bugs Fixed: Stability
  • Cannot save voice recording and may freeze after selecting not to save voice recording
  • Player sometimes freezes when entering Photo A-Z
  • Unplugging the micro SD card while saving recording may cause the player to malfunction
  • Player may not function properly after resumed from Standby and deleted FM Presets or deleted Recording
  • Player may not function properly after resumed from Standby and removed micro SD card from player
 Video playback
  • Long video playback may cause player to freeze
  • Some video content from Amazon Unbox in Portable Device format may cause player to reset during playback
 Audiobook
  • Player shows wrong chapter numbers after changing to playback in another Audible file
  • Player sometimes displays incorrect elapsed time when playing an Audible file
  • Fast Forward and Rewind speed do not accelerate when playing back Audible files
  • Displayed chapter number of Audiobook may flicker when refreshing playback screen
  • Text scroll speed increases after selecting "Back to Audiobook List" when playing an Audiobook
  • Player sometimes does not move to next chapter after pressing Next key
 Localized firmware for Pacific Rim region
  • Incorrect Thai translation of Main menu strings "Last Played" and “More”
  • Mixed Thai font attributes in Main Menu strings
  • USB Mode default incorrectly set to MTP mode instead of MSC mode after restoring to factory settings
  • USB connection set to MSC mode may change to MTP mode after some usage
  • USB connection set to MSC mode may change to MTP mode if a micro SD card were inserted
  • Video, Pictures, Audible, Playlist and Music folders were not visible in MSC mode
  • Main menu “Last Played” string in Korean has wrong vertical offset
 Miscellaneous
  • Player may display black screen if select “Clear Music Go List” when battery is low
  • Player will not charge when plug into PC or AC charger
  • Player may not charge battery when a micro SD card is inserted and plugged into an USB port
  • Main menu “Now Playing” icon is not displayed correctly when micro SD card is removed
  • Player sometimes does not forward to next music track in the playlist
  • Player may display “Bad Track” error message if continuously skipping backward in a playlist
  • Player returns to original playback screen after deleting a track
  • Screen does not restore correctly when returning from Option or Setting screens
  • Repeat and Shuffle in Music Option menu can be enabled when playing a Rhapsody channel
  • Player turns off LCD during Photo Slideshow
  • Some album art files are not correctly displayed
  • Screen flickers after deleting an FM preset
  • Player may display black screen when deleting FM Radio Presets or Viewing All Presets
  • Player sometimes displays overlapping “Now Playing” and “Last Played” icons
  • Total photo count may be incorrect when conditional “Last Played” Main menu item exist
  • FORMAT command confirmation should default to negative selection
  • Incorrect track count after tracks are deleted
  • Wallpaper does not change when Color is set to “Day Shift”
  • Text scrolling not smooth for easy readability
  Enhancements:
  • Options menu is now available in all content listing screens
  • Database refresh performance
  • Disable FORMAT option when battery is low
Message Edited by sansamonsta on 06-30-2008 02:36 PM
Highlighted
Newbie
Re: Sansa View Firmware 01.02.09 Download
Just did this, everything went flawless.............I LIKE the backlight fade in after being off, nice touch!!
Highlighted
SanDisk Senior User
[ Edited ]
Sweet! I knew you guys would pull through! /The backlight already faded in before this update
Message Edited by Aircraftkiller on 01-29-2008 03:33 PM
"I do not feel obliged to believe that the same God who has endowed us with sense, reason, and intellect has intended us to forgo their use." -Galileo Galilei
Highlighted
Newbie
[ Edited ]
It did? Smiley Very Happy never noticed. LOL
I am curious about his though: Accessory support through 30-pin Sansa Interface
What exactly is this?
Thanks
Message Edited by idbl_fanatic on 01-29-2008 12:48 PM
Highlighted
SanDisk Senior User
[ Edited ]
It probably refers to it enabling the TV out mode properly along with being enabled to pass music through the dock connector into an FM transmitter.
The album art doesn't display properly, which is an issue that dates back since the original firmware if I'm not mistaken. At times it refuses to display art while cycling through small/large art.
Message Edited by Aircraftkiller on 01-29-2008 03:55 PM
Highlighted
SanDisk User
Will the updater software do it automatically on plugging in the View to the computer?
Highlighted
Newbie
Nope, I tried that 1st
Highlighted
SanDisk Guru
It seems like it got to the forums before the updater, probably will be on the updater eventually.
Great For Beginners:
How To Videos
FAQ's and Stickies
Any-Video-Converter
____________________________
- Enigma
Highlighted
SanDisk Professor
Highlighted
Newbie
appriciated the new firmware but still many bugs are still there.......but a good leap though....thanks sandisk and you guys for providing the linksSmiley Wink
