Highlighted
Newbie
Re: Sansa View Battery Replacement
I wish ir had said that on the box.  Junk when battery wears out in 15 months.
Highlighted
SanDisk Guru
Since the View was discontinued something like 7 years ago, the battery is likely far older than 15 months. You could try and find a replacement battery online, but it will likely also be some years old as well.
Highlighted
SanDisk Guru
[ Edited ]
@cindi wrote:
Sounds like I should toss the 50$ sansa after 20 months.  I's dead and the battery won't charge.  I used it three times.  Junk products.
Strike #1: Trolling
Strike #2: Necro-posting
Highlighted
Newbie
I bought one of these, and love it, but the battery did stop taking a charge, and for a long time I just kept in plugged into my car's outlet, but I was able to get a replacement battery, for less than $15, free shipping at:
www.batterybay.net
and instructions to replace it at:
http://www.anythingbutipod.com/forum/showthread.php?t=34095
I hope this helps
