Newbie
Ruckus, Syncing and Sansa View.
I use Ruckus to download music. I have paid for the "ruckus to go" subsrciption but when I go to sync the music to my View, Windows Media Player will not recognize that I have the licences.  Is anyone else using ruckus or having this problem?
SanDisk User
Re: Ruckus, Syncing and Sansa View.
same issue but mine just says acquiring license then it errors never actually says error in acquiring license...
Lame
SanDisk User
WOOOOOOOOOT
I got it working on mine...dont mean to rub it in but this is how i did it.
exited out of WMP and Ruckus
Redid my DRM file like it shows in the help files of Ruckus.com
Opened up ruckus re-upgraded my licensing
Then redid my licenses for all my downloaded music.
You should really make sure you have WMP 11 btw
opened up WMP 11 plugged in device AND BAM synced it NO PROBLEMS!!!
all i can say is try and mess with your DRM files and try to renew your licensing and make sure you are using WMP 11.
let me know if i can help anymore
Newbie
ok so i did everything it told me to do, it didnt work. i went to the microsoft site link it gives as an alternative way to do it, it didnt work. so if you have anymore ideas, they would be greatly appreciated.  and ruckus is not being very helpful. thanks
SanDisk User
gotta love drm...
Newbie
@Asuma wrote:
gotta love drm...
Especially if you have a way of taking it away when downloaded from Ruckus Smiley Very Happy
SanDisk User
Did you upgrade to Win media player 11 before or after you redid your DRM folder?  Are you using vista?  This could also be a problem.
You may need to downgrad...errr upgrade to a more stable and user friendly OS like XP =P
Newbie
[ Edited ]
I already have wmp11 and i am using vista.
Message Edited by scarletandgray on 01-04-2008 04:54 PM
SanDisk Senior User
[ Edited ]
Message Edited by 1nonly on 01-04-2008 01:49 PM
Newbie
[ Edited ]
azreal when u say u re- upgraded your licensing do you mean you re purchased the subscription or just renewed the liscences on the music
Message Edited by scarletandgray on 01-04-2008 04:53 PM
