Highlighted
Newbie
Accessories for the E280 work for the View?
Well, my beagle ate my E280.  So, I have replaced it with a Sansa View.  I am left w/ a bunch of (valuable/useful) accessories - car and wall chargers, in particular.  Does anyone know if these accessories would work for the View?  These are aftermarket items; I can't remember the name of the manufacturer.  Any ideas...?
Thanks!
Highlighted
SanDisk Guru
Re: Accessories for the E280 work for the View?
Do they have the proprietary connector? If so they should work just fine.
Conversion Box
Did you notice this forum has a search function? Its not impossible to figure that someone else asked your question before you did, and we have answered it(probably multiple times). Check it out! Or Check out the Knowledge Base
Highlighted
SanDisk Professor
does you beagle has a USB port? Smiley Tongue
Highlighted
SanDisk Senior User
I bought a bunch of accessories meant for the e280 on eBay (chargers, adapters, cables, etc...), they all have stickers with e280 written on them, and they work perfectly on my View.
V.
