I don’t see any differance in the high and low setting of my sansa 2gb fuse. I don’t think this is normal. Can anyone advise. Thanks
well after you switch the volume settings, go back to the song that is playing, turn up or down the volume and you’ll see that the position that the “blue bar” is in, it’s different than what it was in the previous setting
