Newbie
XP issue
i've read most the posts about xp not working. i got it to work on my bothers computer when visiting him. he copied all my music and audio books to his computer then reformated the fuze.
when i got home my xp pro sp 2 will not see the fuze in the auto mode or mtp; when i change the msc i can see the fuse and my extra 8 gig card. BUT, i can't see any of the music.
i have music on the 'native' 8 gig that is built in that will be lost if i have to reformat it again.
i did some searches and even tried it on my 'debian' linux machine with the same results listed above.
gosh! you'd think if sandisk wanted to keep people they'd put a patch out to fix this thing. i've got 2 cameras that don't have an issue, my usb scanner works fine, my 3 'thumb' drive work great. it can't be that hard.
SanDisk Guru
Re: XP issue
MTP mode connects to Windows Media Player, but it has to be WMP 10 or 11.
XP came with Windows Media Player 9. Upgrade it to WMP 10 or 11 at Microsoft
and the songs should appear.
Your computer can see only one mode at a time: MSC (where your songs aren't) or MTP (where they are but you need WMP 10 or 11).
Can't Connect? Other Problems? Answers
SanDisk Guru
Re: XP issue
your cameras scanners and thumb drives are MSC devices. MTP is a Windows media player and rhapsody thing. So Id you Download and install Windows Media PLayer 11, or you go to Microsofts site and get the MTP porting kit, it should work fine.
Conversion Box
Did you notice this forum has a search function? Its not impossible to figure that someone else asked your question before you did, and we have answered it(probably multiple times). Check it out! Or Check out the Knowledge Base
Newbie
Re: XP issue
thanks
somehow when i upgraded my processor, memory and harddrive on my xp pro machine, xp  wont let me validate to get wmp 11 and i'll be da**ed if i'm going to pay them more money! it tookquite a bit of work to get around my upgrade.
so are there anyother solutions? i can see why ipod is so popular cuase my brother doesn't have this issue at all
Newbie
Re: XP issue
mtp porting kits. hope it doesn't require vaidation! thanks though
Newbie
Re: XP issue
nope they want a validation too. i'm not paying a dime more
anyone know how to make linux work with this device.
SanDisk User
Re: XP issue
Yep. Just use the msc mode. Rythmbox works just fine to synchronise, although I prefer to have my music organised by folders (named artist-album) including the art cover as "folder.jpg"
SanDisk Guru
Re: XP issue
If all the music and books were copied onto his computer then what is it that you will lose if you reformat? The simplest solution for you is copy anything on your machine onto his computer, format the player, switch to MSC, then add everything again, and it'll work on your own computer then.
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk User
Re: XP issue
I don't understand… do you lose your music when switching to mtp mode?
SanDisk Guru
Re: XP issue
No. Just the ability to see the files added in MTP mode. Files are only visible & accessible in the mode in which they were transferred to the player in.
The suggestions you've been given is a work-around of sorts. Since you can't (or won't) upgrade to WMP 10 or 11, the concensus is to simply use MSC mode.
Which, even without your current situation, is a marvelous idea. There is life after WMP. You don't need it. Smiley Wink
