Using external memory SD Card
I have put in a 32gb sd card to the external but it will not recognize it (mp3 player)  and the songs on it.  My Sansa is like 8 years old and doesn’t look like the the new ones.
Have you tried using another SD card? Just want to rule out the possibility of a bad card though.
What model is it? Chances are if it is that old it will only recognize the SD (2 - 16GB) format and not the SDHC format (32GB). There is no way to upgrade it, unless you use the 3rd-party firmware Rockbox.
Please see the suggestion in this post:
http://forums.sandisk.com/t5/Sansa-Fuze/Music-files-very-big/m-p/330383/highlight/true#M52044
