SMConverter doesn't recognize sd card
I’ve been using the sansa media converter to convert video files for over a year now and I haven’t experienced any problems until now. The converter recognizes my sd card as 2 gb but in reality it’s 8. I’ve used this same sd card for previous conversions. I deleted some old files to replace with new ones. Some new ones were said to be added but when I looked at my fuze, the files weren’t on there. I checked through the computer and couldn’t find them. It said that I had no files on it. Thanks in advance.
Message Edited by sansafuze123 on 01-28-2010 09:54 PM
Try format card first
I figured out the problem. It converted the files onto my usb that that was hooked up. Thanks though.
