Turn on suggestions
![]() Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Showing results for
Topic Options
Recording Problems?Options
04-22-2009 04:33 PM Well I was recording some stuff and I listened to my recordings and i noticed wierd sounds (like the sonuds you hear when there's something wrong with the T.V chanel and makes a buzzing sound). The stuff I recorded wasn't realy loud, and my last mp3 (sansa express) and my sisters mp3 (sansa c200) worked and didn't have any wierd sounds. For example when I put my mp3 about 10cm (sorry i'm not sure how much inches that is) from the speakers on my cp (which were set at a pretty low volume) I heard wierd sounds when I listened to the recording i heard buzzing. Re: Recording Problems?Options
04-22-2009 06:19 PM
What is a cp? Don't put it so close to it, whatever it is. The microphone should pick up almost anything in a normal size room. It's not magic, but they are quite sensitive.
DAPs: Fuze 8GB+16GB for office, Meizu miniPlayer 4GB for the car, Clip 8GB for walking around.
Headphones:: Sleek Audio SA-6 (treble ++), Koss KSC75 modded, Grado SR-80i, Grado-225. |
