Does anyone have problems with the radio drifting from the station it is supposed to be tuned in on? I have good broadcast and most the stations I listen to drift off the band. Only solution is to move the selector one way or the other than back to the station. This is good for a short while then the problem is back. It is almost like the Fuze can’t lock the station in. Less than a month old and it came with this problem. SHOULD I TAKE IT BACK FOR A ANOTHER ONE or is this a problem with this model? Scott
Apparently, you’re not alone:
http://forums.sandisk.com/t5/Clip-Clip/Radio-tuning-drift/td-p/213809
http://forums.sandisk.com/t5/Clip-Clip/FM-quality-deteriorating/m-p/210504/highlight/true#M33452
OK Thanks. Other people having the same problem, looks I will make a visit to where I purchased it. Thanks
