Highlighted
Newbie
Radio Removal in sansa fuze v2
Hi, There is a firmware version for sansa fuze v2 without a radio?
because I whant to remove the radio from my player (I saw a version without radio to fuze v1 but not to v2)
thanks!
Highlighted
SanDisk Guru
Re: Radio Removal in sansa fuze v2
Look on the Clip+ board. Someone mentioned how to do it on the Clip+. Doing the similar thing might also work on the Fuze.
Highlighted
SanDisk Professor
[ Edited ]
The steps provided on this thread might work as well with the Fuze V.2
Download the manual update here. The extracted file should be "fuzpa.bin" simply rename it to fuzpg.bin and transfer it to the root directory of the Sansa.
Highlighted
Newbie
It's works! thanks a lot!
Highlighted
SanDisk Professor
You're welcome Smiley Very Happy
Highlighted
SanDisk Guru
Now please enlighten us why you wanted to remove the radio capability in the 1st place. I'm dying to know. Smiley Tongue
Just because it's there doesn't mean you have to use it. You're certainly not going to gain any more memory space by not having it there.
Highlighted
SanDisk Professor
One option less to scroll by.
