Highlighted
SanDisk Guru
Re: Overdrive Media Console - updated Fuze firmware and can no longer download audiobooks
Time to call 1-866-SANDISK and ask the pros.
Highlighted
Newbie
Like many others I tried all the other suggestions (reloading overdrive, formatting from WMP11, etc.), but none worked. On a whim I switched the Fuze USB setting from MTP (recommended) to MSC, which is supported by Overdrive and WMP11. Don't know why, but it transfers fine now. To me this indicates that the problem is not the Fuze clock, nor Windows DRM, but some bug in either Fuze or Overdrive.
Highlighted
Newbie
Thank you! I did not know how to do the sync-ing but I tried your simple solution and it worked! After that I found a blog reporting a link between Windows Media Player 11 and Sansa download problems. It recommends rolling back to an ealier Windows Media Player version. I'm trying that too.
Highlighted
Newbie
[ Edited ]
Rolled back to Windows 10. MP3 transfers on USB AutoDetect but not WMA. The best suggestion so far is to try the alternate USB settings for WMA transfers.
Highlighted
Newbie
Thanks, kmk_01kmk.  Your suggestion also took care of the same issue I was having with my Sansa Clip Zip after a firmware update.  Worked like a charm.  Don't know what the process would be, but this "little jewel" should be shared with the Customer Support folks that answer the phones.  Their suggestion to format my device and reinstall the firmware got me no where of coarse.  Their next suggestion was to REPLACE the device.  Excellent work!
Highlighted
Newbie
If you have a Sansa Clip Zip and you get this message:
"Error detail: Unable to insert selected title. Error 0xC00D2779: the file could not be transferred because the device clock is not set."
Here is how to fix this problem in less than a minute: Set the clock on your device.
1) Turn your device on
2) Click Menu tab top left of all tabs
3) Scroll through menu options to Settings
4) Click center tab to enter Settings
5) Scroll down Settings to System Settings
6) Click center tab to enter System Settings
7) Scroll down System Settings to Date
8) Click center tab to choose Date
9) Set Date correctly and press center tab to save and return to Sys Set
10) Scroll down System Settings one more notch to Time
11) Set Time correctly and press center tab to save
Your done. Your Zip will now accept anything from OverDrive Media.
Enjoy your audio books!
