Highlighted
Newbie
Need a charger
I lost my Charger but my Sansa is an old Model will a charger from a newer model work on mine?Mine is the tallest one
Highlighted
SanDisk Guru
Re: Need a charger
You have a Sansa View.
I believe Sansa used the same 30-pin cable for E200, Fuze and View.
Here's one that is supposed to be original SanDisk.
http://www.amazon.com/Sandisk-Connector-GENUINE-Connect-Players/dp/B00OQPB1JO/ref=sr_1_4?s=electroni...
You can also search for Fuze or E200 Synch or Data cables online.
