Missing Volume option in System settings
Hi, I’ve just brought two new 8Gb Fuze’s but there is no option to change the Volume setting to High in System Settings. I have an 18 month old Fuze and mine has this option. Can anyone help ?
Firmware V01.02.26f
 Thanks
What region is it set to.  If it’s set to Europe, it could be that has been removed due to European restrictions on portable player output.
If you don’t know, set it to defaults, and then it will ask you what language and what area to use. (North America, Europe, Rest of World)
I choose “Rest of World” because it removes the SlotRadio tab and the Rhapsody Channels tab, which I don’t use.
Thanks for your reply Opus -  your work around fixed the poblem , cheers !
