MicroSD Card Question
I have a 2GB Fuze (already full), and have just purchased an 8GB microSD card.  Question: can I “drag and drop” the music loaded on my Fuze internal memory over to the new microSD card to free up space, or do I need to “reload” my playlists to the new card by using WMP or “drag & drop”?
Thanks for your help!
Rick
On my 8g fuze, I have been able to drag and drop bewteen the device and the card using the two separate windows of Windows Explorer.
Thanks for the info - it’s kinda what I surmised, but as I’m still a noobie to the device I wasn’t sure.  Second question I forgot to ask, pertaining to the first:  Does that method keep the song info when playing (album pics & stuff?).
Thanks again!!
Rick
You can drag songs over to the microSDHC card, but I don’t think playlists will recognize it anymore. You’ll have to make separate playlists for the microSDHC card.
It will certainly update the song info, but whether the album art gets copied over depends on what version you’re using, how the album art is stored, and how you copy it. Older versions (prior to the release a few weeks ago) didn’t recognize album art in the song, so you had to have an art file (usually folder.jpg) in the directory with the songs. To keep it from showing up under pictures, it had to be hidden. If you use Explorer to copy the entire directory, that art file will get copied over. If you just copy songs within a directory, by default a hidden file won’t show up and thus won’t get copied.
