I have Rockbox on my Sansa Fuze. Ever since I got it, my computer charges the battery but doesn’t recognize the device! How could this be? Any solution?
Ever since you got Rockbox, or your Fuze? What USB mode is it set to?
Do you plug it while Rockbox is on. If so, you need to shut it down and plug it again. Rockbox doesn’t support data transfer yet.
it is possible that there is a bent pin or cable problem.
I thought that Rockbox supported data transfer on the v1 since it became stable? Or am I just so out of touch from being absent for so long?
