Highlighted
SanDisk User
Accepted Solution
Can you please help me in deciding between Fuze, Clip+ and E270?
Hi!
I have finally decided to buy a SanDisk MP3 or MP4 (which anyway I will use just for music).
I look for something small, with long battery life, and the best possible audio quality and features (like customizeable equalizer to fit my earphones needs, and several random features). And of course, price.
And, also, comfort (for example, sided earphone plug on Clip+ is not a good solution to put it in the pocket, neither is the clip), easy to use, if buttons are solid and silent, or if they do a terrible CLICK, etc...
I understand that each one of these is the best in one field? Fuze and Clip+ are the smallest ones, E270 is the one with more battery time (especiallybecause I can have an extra battery - which I do not understand if it comes with the player or if the player just comes with one).
I also need to use a MicroSDHC Kingston, 8GB, with it.
Can anybody tell me aboutr his experience with one or more of these players please?
SO I can understand well feaures and differences directly from the field, by the real users...
THANKS!
Highlighted
SanDisk Guru
Re: Can you please help me in deciding between Fuze, Clip+ and E270?
The Fuze is your best bet. It has better sound quality than then Clip+, its battery life is fine and it's small. The EQ is not great in any of the Sansa players.
The E270 is bulkier and you won't know until you get it whether you have a v1 (lower sound quality, only uses 2GB card unless you install Rockbox) or v2 (Fuze sound quality, any microSD card).
The Fuze headphone jack comes out the bottom but you just put it in your pocket upside-down. Fuze buttons are solid. It does click, but so do they all.
The Fuze power button, a slider you have to hold up for a few seconds, does require a bit of thumbnail or fingernail to use.
You might look at anythingbutipod.com , although in my opinion they are wrong about the sound quality of the Clip +.  I played my files on both Fuze and Clip+ through the same headphones and the Fuze was clearly superior.
Highlighted
SanDisk Guru
'The Fuze is your best bet. It has better sound quality than then Clip+"
Not really, although maximum volume is a bit greater on the Fuze than the Clip+.
Highlighted
SanDisk Guru
I compared them through 29 ohm impedance headphones. Perhaps 16 ohm doesn't show any difference. The Clip+ also has lower battery life. And the clip itself isn't removable, which would have made for a nice tiny device.
Highlighted
SanDisk User
I find the sound on my Clip to be slightly better than the Fuze but both sound great.  I use the Fuze more for general listening because of the features.  I use the Clip for working out because of the size.  Both can be had for cheap refurb'd, why not get both?
Highlighted
SanDisk Guru
Clip or Clip+ ? They're different hardware, besides the fact that Clip+ has a microSD slot.
Highlighted
SanDisk User
Ah, this would be so interesting. SO, Clip sounds better than Clip+?
I have not clear the impedance theme, I like technical matters but I miss this. Anyway I understand the concept.
Do you think it may depend on the equalizer? I mean, may it be that you were listeing in Fuze with a better equalizing settings? I guess a test should be done with flat equalizing... If you still own both devices, it would be interesting to know if with a flat equalizing you canhear difference in the reproduction quelity of the same song, with same earphones, and even better if you can try both 16 and 29oms...
But this is just for curiosity, I guess it is not such a big deal.
Yes, I am disapponted too with their decision of making the clip fixed in Clip+, I was so hapy with the idea of a removable clip, so that I can use it without clip when I have to put in my pocket...
A question about E270: I had understood that no E270 may be V2. Only E280 can be V2 I guess, or anyway, never a E270.
Also, the lesser sound quality comes from the chipset (no solution) or from firmware (solution: rockbox).
And why should rockbox not be a good thing? I tell you that I have no idea about that, it is just a real question.
So, the three of them have clicking buttons? Mpf...
DO you think E200 are cofortable to carry on frontal jeans pocket?
The customizable equalizer is only on CLip?I have read that I can set 5 bars equilizer as I like. I find it useful to adapt the sound to my hearphones...
Highlighted
SanDisk Guru
 Its exactly the same hardware, so probably not.
No all models can be either V1 or V2.
Rockbox is the only way you'll get a good EQ, but IMO EQ is not so important for portable unless you have odd headphones.  On the e200v1 Rockbox is the only way to go.  On the other models its a toss up since the rockbox port is much newer and not nearly so well refined.  Theres no rockbox at all on the Clip+ or the V2 Fuze/clip.
Yes its about the same volume as a Fuze.  I use it as my main player due to good rockbox support.
Highlighted
SanDisk Guru
[ Edited ]
The 6GB memory size was unique to the v1 devices.  The v2 devices were manufactured in 2, 4, and 8GB versions.  The e270 designation is unique to the v1.  It's the one e200 model that easy to find whether it's v1...well, it was also released as a Rhapsody model.
Bob  Smiley Very Happy
Message Edited by neutron_bob on 01-23-2010 07:49 PM
Highlighted
SanDisk Guru
Oh I never noticed that, but now that you mention it, I don't recall seeing a 6GB v2.
