Highlighted
Newbie
Re: Can i downgrade my firmware?...
i put it as a solution but it didnt work i have a version 1 so i think thats y it didnt work
Highlighted
SanDisk Fanatic
 Then you didn't do it right!!  Re read and try it again!!  maybe others can help you out!  George
*His* 8GB Silver Fuze v01.02.31A also 8GB MicroSDHC card installed *Hers* 4GB red Fuze with 16GB micro SDHC card! Firmware v01.02.31A still installed. Acquired another 8GB Fuze also with firmware v01.02.31A now..
Highlighted
SanDisk Fanatic
Your choices of firmware will be!!  v01.01.11   v01.01.15   and the latest v01.01.22..  They all will load as stated manually!  George
Highlighted
SanDisk Guru
[ Edited ]
You only linked to one firmware, and it's for the v2 Fuze.
Here's the link to the previous v1 firmware. Then follow the rest of George_W's directions.
Message Edited by gwk1967 on 01-11-2009 07:26 PM
Highlighted
SanDisk Fanatic
[ Edited ]
 I didn't mean to link to anything.. I just copied and pasted , it was there!! I'm sure he can do some of the work and search for the firmware he wants to install!!  But I'll make it as easy as I can for him!!  Here is a link for the last firmware!George
This is for 01.01.15
if you want  version 01.01.11  it's posted look for it!! Took me all of 15sec to find this link..
http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&message.id=4894&query.id=48906#M489...
Thank You gwk1967!!! I didn't see you posted the link for the previous firmware!!  George
Message Edited by George-W on 01-11-2009 08:30 PM
Highlighted
Newbie
if your having trouble transfering the .bin file, try switching your fuze to msc mode, to do this go on your fuze and go to settings: usb mode: and click msc, then follow the previous intructuions, it should work then.
