Highlighted
Newbie
Accepted Solution
Can i downgrade my firmware?...
i like the 1 before the latest better
Highlighted
SanDisk User
Re: Can i downgrade my firmware?...
what don't you like about the new one?
Highlighted
SanDisk Fanatic
Yes you can!  You need to do it manually by dropping the bin. file you extrackded to the root directory. But I agree with the last poster. Why would you like the last version better? IMO Sandisk did a great job with the latest firmware upgrade!  Very close to bug free..  In fact for what I use my Fuze for I have not see a bug in the latest firmware v01.01.22a! George
*His* 8GB Silver Fuze v01.02.31A also 8GB MicroSDHC card installed *Hers* 4GB red Fuze with 16GB micro SDHC card! Firmware v01.02.31A still installed. Acquired another 8GB Fuze also with firmware v01.02.31A now..
Highlighted
SanDisk Guru
lukev hit the nail on the head. What exactly dont you like about the current FirmWire?  Is it a function issue?
Conversion Box
Did you notice this forum has a search function? Its not impossible to figure that someone else asked your question before you did, and we have answered it(probably multiple times). Check it out! Or Check out the Knowledge Base
Highlighted
Newbie
yes now my album art doesn't show when i sync music
Highlighted
Newbie
how exactly do you do it?
Highlighted
SanDisk Fanatic
[ Edited ]
Info was from the first page of the Firmware update page!!  Here you go!!  ONLY USE the Firmware of your choice..
All Regions - Click here to download
All languages are now in one firmware version. After firmware update you will need to select your Language and Region preference.
• Ensure your battery is > 50% full.
• Extract the .zip file into a folder on your computer.
• Once extracted, drag the file to the root directory of your Sansa Fuze.
• Disconnect the Sansa Fuze and let it begin the firmware update.
• Once it finally finishes doing its update, it will turn itself off.
• Turn the Fuze on Select your language and region preference
• Once its back to the main menu, head to "Settings" > "System Settings" > "Info", and verify the "Version" is now 02.01.17"x
Message Edited by George-W on 01-11-2009 06:38 PM
Highlighted
Newbie
what is the root directory?
Highlighted
SanDisk Fanatic
Explore  " my computer" click on the Fuze then click on the internal memory..  Here you will see a few folders.. Drop the extracted firmware of your choice in here but not in any of the folders!!  Let it load.  When done unplug fuze and let it update, it will turn itself off when done..  Tune it back on then chose you region..  That's it..  George
Highlighted
Newbie
didn't work
