SanDisk Guru
Re: Best earbuds for under $20?
@shenanagins1091 wrote:
Well, if not skullcandy, then I'm getting these:
http://www.amazon.com/exec/obidos/tg/detail/-/B0012UIJ9G/ref=ord_cart_shr?%5Fencoding=UTF8&m=API0ESPAS70OH&v=glance
Match my red Fuze. Smiley Tongue
I have 40% hearing loss, it only gets worse, I work in Radio, have played in Rock and Metal bands since I was 7. ALL I USE IS SKULLCANDY. I do have a set of $200 Shure IEMs for stage shows. But In the radio Studio Skull Candy TiTan IEM, Remote recevier (its how I hear realtime radio when I do a live remote) Skull Candy Ink'd, Sansa Products, Skull Candy Full Metal Jacket.  I swear by them. If they go under ever I will not know what to do. Try the Cany... you wont be sorry.
Conversion Box
Did you notice this forum has a search function? Its not impossible to figure that someone else asked your question before you did, and we have answered it(probably multiple times). Check it out! Or Check out the Knowledge Base
SanDisk Senior User
I love my Marshmallows, they have good balance between treble and bass naturally without any EQ. I'm not so sure about Skullcandy because I have heard more complaints than I have compliments, but you could always try them!
Gabe Smiley Wink
Newbie
You could find useful options in the following link which lists some of the best earbuds that you can find.
SanDisk Guru
Congratulations on resurrecting a five-year-old thread.
http://lifehacker.com/the-best-headphones-you-can-buy-under-20-1480550409
