jl
Newbie
volume
I updated to firmware 30A but my volume is still too loud at the lowest setting, especially in a quiet environment. I know I can get an in-line volume controller for my headphones or adjust the volume before uploading the files to the clip but I shouldn't have to go through these extra steps. Does anybody know of an easy fix? Changing the clip's volume setting from normal to high does not make a difference. Thanks.
SanDisk Guru
Re: volume
If you turn on the custom equalizer,  you can pull the sliders down evenly and add extra attenuation to the sound level.
