Highlighted
Newbie
sound clipping
I don't now if this is something I should be doing but I am trying to play my clip+ through my home stereo. I run a line out of the headphone jact into an imput in the back of my stereo. The sound seems to be "clipping" or dropping off. Can anybody help me with this problem. If I can't us my mp3 player in this manner then I really have no need fo it.
Highlighted
SanDisk Guru
Re: sound clipping
Try turning the volume up all the way on the Clip+ and then use the volume control of the stereo to raise or lower the listening level.
Highlighted
SanDisk Guru
Re: sound clipping
There are a few factors involved.  Most notably, is playback normal through headphones?
If so, either there is a gain issue, a load issue, or a plug problem.  Normally, run with the volume at three-quarters of scale or higher, and adjust at the stereo.  If the plug has a problem,try pulling the plug out slightly, and see if the sound clears up, or it might be the opposite problem, the plug might not be fully inserted.
If the load is excessive, under 16 ohms, on your stereo, the output might be clipping on the player.  This situation is unlikely but possible.  Incidentally, dropping out of audio on the Clip can be caused by a problem plug, at it may be shunting one channel to ground.  The drop out sound if the protection circuit of the headphone amp.
This protection can activate if you are using a two-conductor (mono) cable, as it shorts the two (L / R) outputs together.
Bob  Smiley Tongue
Highlighted
Newbie
Re: sound clipping
I will try a different plug and see if that makes any diff. By the way I have to turn the volume on my amp all the way up to get decent volume.
Highlighted
Newbie
Re: sound clipping
Tried a different plug and that fixed the sound cutting out. Thanks Smiley Happy
But I still don't get a lot of volume. Could it be I just need a better player?
Highlighted
SanDisk Guru
Re: sound clipping
Make sure the player's EQ is set to "Normal"
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
Highlighted
SanDisk Guru
Re: sound clipping
The EU volume limitation may be an issue with your device. Normally, when playing through an external amplifier, set the volume up to maximum, which is best.  Don't worry, you're playing through a higher impedance load than headphones, so battery life will be jst fine.
Don't forget to turn down the volume before using headphones later.
Under Settings > System Settings > Volume set the device to "high", not "normal (limited).  If you do not have the volume option available in Settings, change your Region to Rest Of World or North Amnerica, and you'll have the available setting.
Bob  Smiley Very Happy
Highlighted
SanDisk Guru
Re: sound clipping
[ Edited ]
Make sure you aren't using the phono input on the home stereo. Plugging anything but a phonograph into that will cause problems. As others have said, it may be a problem with the cables, or perhaps the contacts on the stereo input are dirty and not making good contact.
Highlighted
Newbie
Re: sound clipping
Tried all of the above. New cables and I still get sound clipping (if that is really what is happening) if I turn the volume up to max on mp3 player. The volume on my amp is almost up all the way. This should be way too loud to sit in front of the speakers but not with this unit. I have no experience with these little mp3 players. Maybe it is a problem with these things. I us a portable cd player like a walkman to play mp3 cds through my amp and get tons of volume. Still looking for the right answer. Thanks for all the suggestions though.
Highlighted
Newbie
Re: sound clipping
By the way this happens on two different amps! Also if I play  mp3 player through my computer via the usb hookup through an amp the volume is normal. gets very loud and no sound clipping.
