Highlighted
Newbie
sansa clip on buttton on top right
when recording lecture  tells  me memory full  i have external drive with plenty  space  free w\please help me
Highlighted
SanDisk Guru
Re: sansa clip on buttton on top right
If I recall correctly, the player records to the internal memory alone.  And so, an easy fix:  move some contents from the internal memory to the external card--voila, you now have your needed space!
Highlighted
Newbie
how do i move  from internal memory  to external memory  thanks  do u have phone  i can  call u
Highlighted
Newbie
how do i move from internal to external  memory
Highlighted
Newbie
how  do i  do that
Highlighted
Newbie
howdo i do that
Highlighted
SanDisk Guru
You need to do it with a computer. Just connect, cut and paste.
Highlighted
Newbie
i did that  and still said  memory full maybe i didnt  delete enough ?
do u havbe phone # i can call u for help
tks
Highlighted
SanDisk Guru
Just copy and paste more files from the internal memory to the external memory card.  But be sure that you then delete the songs (that you have copied and pasted) from the internal memory card--maybe you forgot to do that.
Also, note:  most people aren't here providing "real time" assistance--and so it can take some hours, or even a day or 2, for people to respond to you.
SanDisk can help as well, including via free telephone call from you:
http://www.sandisk.com/about-sandisk/contact-us/
Highlighted
SanDisk Guru
Also know that recordings made on this device (whether radio or voice) are saved in WAV format, which takes up a lot of memory space.
What size is your internal memory? How much space do you have free? How long (and how many) are the recordings you are trying to make?
