Highlighted
Newbie
podcasts problems
Could someone explain to me how to play podcasts one after the other without having to keep using the menu.I am afraid I am not that computer savvy.I bought this to replace a really cheap mp3 player which played one after the other.I am annoyed this sandisk seems unable to do this
Highlighted
SanDisk Guru
Re: podcasts problems
[ Edited ]
I don't use Podcasts, but doesn't it have a Play All button at the top of the list?
Otherwise, go  to your Podcasts folder, scroll to the podcast you want and hold down the center button. That adds it to your Go List, a playlist that will play them in order. Choose whatever ones you want to hear and just add them to the Go List.  Then go to Playlists under Music and play the Go List.
