Newbie
location of older firmware
I have several clip+ players. The first ones I bought had firmware 01.01.05A version and worked fine for me. The last ones I bought had version 01.02.15p (latest) and these have problems with disappearing files on the external microSDHC. I have checked and verified that it is NOT the microSDHC chips as these all work as advertised on the first players so what I need to do is load the older firmware to correct this problem.
Where do I find the older firmware, specifically 01.01.05A?
Thanks,
Perazim
SanDisk Guru
Re: location of older firmware
An archive of the Clip+ firmware that SanDisk has separately issued.  I don't believe that SanDisk ever separately issued the firmware version you originally had, however.  The archive starts with version 01.02.15.
http://www.anythingbutipod.com/forum/showthread.php?t=51524
(The Anythingbutipod Clip/Clip+ forum also has an archive of the available original Clip firmware, by the way.)
I do wonder about your situation, as I don't recall hearing that newer firmware has caused a microSD card issue (a pretty big issue for SanDisk).  Could it be the content on the card?  What happens when you put the card in your first ClIp+ players--do the missing files show up?
I also wonder if a format using the SD Association's formatter tool might help.
https://www.sdcard.org/consumers/formatter_3/
SanDisk Guru
[ Edited ]
It starts with 01.02.15 because that was the most recent, but there are a few earlier ones following it....the earliest being 01.02.09. Smiley Wink
iPod Touch 5G 32GB, Touch 4G 32GB, Clip Sport 8GB.
Rockbox-> Clip Zip 4GB, iPod Nano 2G 4GB, iPod 5.5G 80GB
2012 Nexus 7 32GB, Asus MeMoPad 8 16+64GB, LG Optimus G Pro, Nokia Lumia 900, Nokia Lumia 520
SanDisk Guru
Cool--thanks. I didn't read through the archive thread (too lazy). Smiley Wink
SanDisk Guru
[ Edited ]
Well, I am the author of that post, after all.....so I know what's there. The links to the different firmwares are all in that first post Smiley Wink
SanDisk Guru
Yes, indeedy, scrolling down does help!   Smiley Wink
Newbie
I reformatted using the recommended formatter. This SEEMS to have resolved the problem. Will know for sure over the next few days. Thanks
SanDisk Guru
Cool!    Smiley Happy
